Fix broken Digitizer Seal or replace it?
I am in the process of repairing an iPod Touch 2G's Digitizer. What is the best way to do it Replace the entire Digitizer or replace the rubber frame under the glass?
Esta é uma boa pergunta?
you just change the Digitizer . this is little hard as compare to if you get the touch with the rubber panel then its very easy to take out the old one and place the new one there . see this is the way to change the front panel
iPod Touch 2nd Generation Front Panel Replacement
after removing the front panel :
2 step is to Like the changing the touch of IPhone (3g or 3gs) :
iPhone 3GS Front Panel Replacement
see the step 15 directly . in that he is removing the panel from the touch .
Guia
Nível de dificuldade:
Moderada
45 minutes - 1 hour
Guia
Difícil
45 minutes - 2 hours
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 3,100
