touch pad replacement Asus n53
My top cover broke and I got a replacement for it but comes with no touchpad. is it possible to remove the touchpad from the original cover and install on the new cover? if so how can I do it?
Esta é uma boa pergunta?
Hi @xinwarrior
Based on some research into the ASUS N53 it looks like this touchpad is easily transferred after removing a few surrounding screws.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 11
Ao todo: 617
Can you add pictures of the new cover and the old one, it would help to know more exactly what part is missing on the new one and needs to be moved.
Adicionar imagens a uma pergunta já existente
por Erik Eriksson
Apologies. Unfortunately I've already fixed the device therefore I won't be able to take any pictures.
The touchpad board is actually glued to the cover I had to heat up the touchpad area on the cover (not the board) and used a metal pry tool from my IFIXIT to remove it.
Bit by bit the glue was coming off.
I was able to just stick it to the new cover and is working well
por Joao Araujo
