Ir para o conteúdo principal
Apresentado no Salão Internacional do Automóvel de Nova York em abril de 2003, o Prius foi totalmente redesenhado para o ano modelo 2004 nos EUA. Ele tornou-se um liftback de porte médio, com tamanho entre o Corolla e o Camry, e com a redistribuição do espaço mecânico e interno, o que aumentou significativamente o espaço para as pernas no banco traseiro e o espaço para bagagem.
it isnt working any more
my car is not working any more
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
# The car won’t do anything, period. When the 12 volt battery fails the car won’t do anything. Jump starting is easy with a little lithium battery pack and instructions are in the owner’s manual. Once started, the big “traction” battery will keep the 12 volts going, but once you turn off the car, the dead 12 volt battery will still be dead and the car won’t do a thing.
# You are in snow or ice and the car is running but it won’t move and the engine won’t rev up: This is because one of the front wheels has zero traction. I discovered this strange effect in a ski area parking lot. The car seemed useless and I accidentally left it turned on and in “Drive” when I got out to go for help. That’s when I saw the left front wheel slowly turning as the car just sat there. I put it in “Park”, threw rocks under both front tires, and I was then able to get moving when I rocked it between D and R.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I have this problem too
por Compartilhar
you are going to have to get new cells for your prius
Pontuação 0
Adicionar a sua resposta
احمد ابو حماد será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 767
