Ir para o conteúdo principal
A collection of guides and support to help with washer repair.
3478 Perguntas Visualizar todos
Maytag Bravos X HE Toploader not draining Soap Dispenser
  1. starting several months ago we find about a half cup of water left in the soap dispenser after running a wash. This wasn’t a problem before I have cleaned the tray, find it appears to operate normally, the valves move freely. I have stuck a pin into the 3 tube holes behind it and found nothing clogging it. We have to manually empty the cup before each load
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
This can be caused by low water pressure. The water inlet hoses have screens that can get clogged. Here’s how to clean them:
https://www.familyhandyman.com/appliance...
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks, I will check this out and report back
por
So, as a follow up, I pulled both hoses, there wasn't screens there, but two round plastic sleeves with tiny holes that were a little dirty. I cleaned them and replaced, but the problem remains. Still water in the Detergent cup
por
Mine did that until I leveled the machine. The Front was too low!
Pontuação 0
1 comentário:
Nope, it's level, but glad you fixed yours. I did a full cleaning and that seemed to have done it
por
Adicionar a sua resposta
David será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 31
Duração total: 977
