Ir para o conteúdo principal
Adaptador de alimentação CA para MacBook, MacBook Pro e MacBook Air. Utiliza um conector magnético de autoalinhamento que se desconecta com segurança quando puxado. Os carregadores MagSafe de primeira geração (2006-2012) possuem um conector em formato de L levemente mais espesso. Disponível nas versões de 45 W, 60 W e 85 W.
Can the box be repaired?
I charge from a generator occasionally. There has been a trend of things pugged into the generator dying. I think by turning off the generator while the charger was plugged in, it may have dropped voltage under the acceptable range. What would this do to the box to make it not work, and how can it be fixed?
I’m on my way to best buy, where I’ll pick up a new one because I can’t work without the charger, but I’ll return that if I can get this one running again.
Any help would be wonderful.
Be healthy!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Generators can create surges which can damage chargers, power supplies and systems. I would strongly recommend getting a good surge suppressor for your system and its peripherals. Did you look at getting a UPS? Or an anti-vampire outlet strip? COMPLETE GUIDE TO VAMPIRE POWER
You selected a MagSafe charger what system are you using? Did you check the systems battery? Install this gem of an app CoconutBattery. Take a snapshot of the apps main window and post it here for us to see Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
john o'bryan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 24
Ao todo: 276
