Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Perguntas Visualizar todos
What does appleacpiplatformexpert start:failed mean
I get the error appleacpiplatformexpert start: failed when I start up in verbose mode. Could that be a power problem with the MacBook caused by a third party unbranded charger
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sounds like you may have used a patcher to try to upgrade your system. If you have appleacpiplatform kext in your usb extensions folder, remove it, the installer should l boot normally.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I took out the hard drive and I got the usual kernel panic that I get, unable to find driver for this platform which suggests bad ram but the ram is brand new
por
Adicionar a sua resposta
Cheap gamer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 148
