Ir para o conteúdo principal
A smartphone by LG released November 2012.
4 Perguntas Visualizar todos
Restoring data from a dead phone?
I’ve looked online a bunch but none of the things I found helped.. The phone has been dead for years, found it recently during cleaning. I know there are a ton of memories on it. Also, I THINK the phone model is correct.. it’s been years, but I’m 85% sure the one on the picture is identical.
When i plug the phone into my PC, it is detected.. but not recognised. Does a nonstop loop of connect noise-disconnect noise-device not recognised notification. Cannot turn it on at all, not even a screen lit up. Any ideas?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi
Try replacing the battery -example only and see if the new battery will start to charge.
If it does start charging, allow it to charge >80% before attempting to turn on the phone.
It may be that the depleted/dead battery is causing problems with the power needed to start the phone i.e. trying to charge a dead battery and turn on a phone at the same time.
It’s a small enough gamble
Esta resposta foi útil?
Pontuação 0
1 comentário:
I'm afraid this is beyond battery issue.. The phone used to work on cable charge alone, without any battery.
por
Adicionar a sua resposta
f.karvay será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 75
