Ir para o conteúdo principal
Thermal fuse replaced wires won’t stay connected
I replaced my thermal fuse but after each load the wiring falls off one of the prongs of the fuse. I had to pry the connectors off as this was a 12 year old dryer and first time any repairs need. Once I placed the new fuse I noticed the female connectors were very loose and basically fell off on their own. I tried using pliers to tighten the connectors to the prong but it did not help the issue. I did use electrical tape to hold the wire in place so I could finish my laundry but after the load was completed the piece fell off again. I really don’t want to reconnect this piece after each load of laundry. I’m not sure if I just need to re-crimp the wires or if there are any other solutions I am unaware of.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
do you have any pictures? its hard to fully understand the problem
por
Hi,
Why did you have to replace the thermal fuse?
What caused it to operate?
Has that been fixed?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Solder it into place.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Amanda Webb será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 248
