Ir para o conteúdo principal
The larger edition of Samsung's tenth flagship Galaxy phone, released in February 2019. Shipped with Android 9.0 (Pie).
107 Perguntas Visualizar todos
Camera failed after software update
Hello all,
So after the recent Samsungs update, my camera functioned fine until a few days ago where I opened it to take a picture of something. The camera froze and I closed it through the multi task bar, and when i went to go open it again i now get a “WARNING; CAMERA FAILED" error everytime I open it. None of my other camera related apps work either now, such as snapchat as it tells me it can't open the camera. I've tried clearing my cache, tried soft and hard reboots, and still nothing. Any ideas?
Update (03/30/2020)
No a factory restore is the last thing I want to do. I've tried the safe mode option to and the camera still fails to open.
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Anyone? Need help ASAP.
por
I have the same problem…..I even did factory reset but no luck …..I have no hopes left…..
por
Adicionar um comentário
1 resposta
Hi,
By “hard reboots” do you mean a factory restore?
If not try starting the phone in safe mode and see if the camera works.
If it does then a downloaded app is the cause. The trick is to find out which one.
If still no good try a hard reset (factory restore)
Be sure to backup the phone first to the cloud or a PC otherwise you will lose all your data and downloaded apps.
If it works then restore the phone with the backup and try again
If still no good try reloading the firmware using ODIN - look online for how to do this.
If still no good you have a hardware problem - maybe just coincidental to it happening after the update. Was the phone dropped?
Esta resposta foi útil?
Pontuação 0
2 comentários:
No a factory restore is the last thing I want to do. I've tried safe mode as well and it still fails to open.
por
@7LineArmy 7
It might be the only way to prove it is a software or hardware problem, but your choice
por
Adicionar a sua resposta
7LineArmy 7 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 628
