The throttle will not return to full idle.
After cutting, the throttle will not return to full idle. How to repair?
Esta é uma boa pergunta?
If by now you have used this unit for two seasons, you will have to replace a muffler.
Two cycle engines will produce more afterburn and will eventually clogged the muffler. Result, an engine that will not idle. In my case the fix was an easy one. I drilled a couple of holes in the muffler. It is not a warranted repair. But it did work for me. Thanks for asking. Matt of Martins TV Repair.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 11
Duração total: 233
Throttlewillnot return all the way
por Joe Godfather
