Ir para o conteúdo principal
Echo SRM-225 Trimmer. This model replaced the SRM-210. The most common repairs for this device are straight forward and can be done quickly.
23 Perguntas Visualizar todos
The throttle will not return to full idle.
After cutting, the throttle will not return to full idle. How to repair?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Throttlewillnot return all the way
por
Adicionar um comentário
1 resposta
If by now you have used this unit for two seasons, you will have to replace a muffler.
Two cycle engines will produce more afterburn and will eventually clogged the muffler. Result, an engine that will not idle. In my case the fix was an easy one. I drilled a couple of holes in the muffler. It is not a warranted repair. But it did work for me. Thanks for asking. Matt of Martins TV Repair.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jim Baccus será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 226
