Computer keeps crapping out om games
Hi guys and girls..:)
so, about a month ago, i decided to build my self a New pc. I’ve put it together myself as I've done that multiple times, so it’s no issue - and the PC’s running fine most of the time.. However, when i play games (AC3, MW, CS GO and the likes of that) my PC freezes to the point where i have to force reboot it.. The error manifests after everything from 2 minutes to 3 hours.. I’ve taken it apart and put it back together again and checked for bent pins on cpu, badly seated ram/gpu, did memtest86 turning back no errors, stresstest the cpu for hours - no issues, done benchmark and stresstest on gpu with no errors - and still it craps out Every time.. It’s quarantine season i’m sure my girlfriend would appreciate any help you guys can give as I'm losing my mind here..:D posted picture of hardware list as well..:)
Fractal Design: Node 304
Intel: i5-9400F (6k - 4.1GHz)
Noctua NH-L9i
Asus STRIX Z390-I Gaming
AMD RX 5700 Grafikkort MSI MECH 8GB
16GB 3200MHz Kingston HyperX Fury
512GB Intel 660p SSD
3 fans in cabinet
Ram’s set to run xmp
SSD is nvme
Thanks in advance - stay safe!!
Esta pergunta é pertinente?
Have you checked CPU, Video card, etc. temperatures with a program like "HWMonitor v1.41"
https://www.cpuid.com/softwares/hwmonito...
por mike
Hi Mike :)
Thanks for the reply! Yes, i have used HW-monitor to check temps on CPU/GPU, all looks normal. My CPU-fan was a bit low in settings, and i got 60 degrees on CPU with 100% load, but i corrected that to make it spin-up earlier on temps, so now i goes 100% at 40 degrees (Celsius - located in EU), and now i does not reach more than 50/52 at 100% load.
por Mikkel Øgendahl
@mikkill
Hi Mikkel,
So is the freezing problem fixed now?
Funny how in English if something is "freezing" it is because it is too hot!
por mike
@mikkill ,
What capacity PSU is installed, you didn't mention it?
The graphics card manufacturer recommends 750W as the card uses 225W.
Just a thought
por jayeff
@jayeff it's 80+ Bronze 650w Cooler Master MWE.. Hmm.. Maybe i should try to replace it, but it's a bit weird as the products were linked when buying, other models were not powerful enough it seemed..;) Thanks for the suggestion! Much appreciated!
@mike - naaah, it still freezes - and yeah, it's kinda weird that freezing is the chosen word to describe what i suspected to be heat-issues in the beginning..:D
por Mikkel Øgendahl
Mostrar mais 8 comentários
