Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Punctured Battery While Removing
While trying to remove the battery I punctured one of the cells but it still isn’t out yet. There was a tiny puff of smoke at first for a second but nothing now. I am still trying to get all the cells out. Should I be worried about it going up in flames at any moment?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Now that it has been a day, I would put a large piece of electrical tape over the hole. Then very carefully attempt to remove it and I would do it outside and stop at the moment anything suspicious starts. Wear rubber gloves and eye protection.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thanks, I put the Mac in the fridge and then removed the rest of adhesive with dental floss. Thanks for your help.
por
Adicionar a sua resposta
RocketBunnyBoy03 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 25
Ao todo: 376
