Ir para o conteúdo principal
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
542 Perguntas Visualizar todos
Hard Drive isn't working after replacing my PSU?
Today my 1080TI came in the mail, and I installed a 750W EVGA PSU as well. When I boot up, I get an error message, and I realized this is because my hard drive isn’t working (which is where Windows is installed). I have checked my system and my SSD appears, but the HDD does not register to the computer. I can’t even use my PC, since I don’t have an OS. Please help me figure out how to get my HDD working, one thing I have heard is that it can get fried if you use the same cables from the old PSU, but I’m hoping this isn’t what it is.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
It sounds like the +12V is missing. Make sure the voltage setting is correct, and re-check your connections.
If you have a meter, probe the power connector to the hard drive, with negative on the chassis (or a black wire). You should have +12V DC on the yellow wire, and +5V DC on the red.
Bottom line if it’s missing, either the power supply is bad, or shorted out.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Hi,
To add to the answer, use the paperclip test to check that all the voltages from the PSU are OK.
por
Adicionar a sua resposta
Garrison Bates será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 392
