Ir para o conteúdo principal
The Sony Ericsson Xperia X10 was the first Sony Ericsson smartphone to utilize the Android operating system.
12 Perguntas Visualizar todos
How do You fix or replace the Charging Port
I have a Sony Ericsson Xperia X10A and the past week i have noticed a loose charging port. Today the phone will not charge at all. I have changed batteries and chargers, but still not charging. I did some research online and have found that these phone are known for loose charging ports. I have order a new charging port but it doesn't have intrustions with it. I love my phone and it's not even a year old, so i just want to fix it not replace it. Can you help me?
Thanks
Tracy
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Tracy Richards, just make sure that if your phone is still covered under warranty, use it. Don't tear it apart unless you are not covered...
por
Adicionar um comentário
1 resposta
Solução escolhida
Tracy Richards, the service manual is available right here. It will show you how to replace things that are replaceable. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
19 comentários:
Thank you. And no my phone isn't under warranty. Thank you for your help.
por
Thank you for accepting my answer. I hope things will work out for your phone.
por
hey do you mined sending it to me pls at grownupgear@yahoo.com pls
por
Sorry, I don't do emails because of size etc. you should download it here :-) good luck.
por
Hi oldturkey0
Can you set the sharing so i can view the manual
Thanks in advance
J
por
Exibir mais 14 comentários
Adicionar a sua resposta
Tracy Richards será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 11,589
