Ir para o conteúdo principal
The Ryobi P235 is a cordless 18 Volt 1/4 Inch impact driver. Ryobi Washer 690266001 x 2 Ryobi Ring 690258001 x 2 Identified by model number: P235
How do I fix the quick connect coupler?
I was using my impact driver and try to change a bit the next thing I know I tried to pull the bed out and the collar a spring washer and retainer clip fell out. Now I’m trying to figure out how I can put it back together, if not I have to send to a Ryobi repair station and wait 2 to 4 weeks for the fix. Anybody have any ideas
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@chascos sounds like it could have come from the Front Gear Case Assembly. check this guide Ryobi P235 Motor Replacement image 7 and see if you can determine if that looks like it should
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Charles Cosner será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 1,571
