Ir para o conteúdo principal
A ferramenta a laser TBK 958c é uma ferramenta de reparo multifuncional que pode gravar vidro ou ser usada para remover o adesivo que prende o vidro da placa traseira usado em iPhones.
TBK 958A missing iPhone 8 file. How to find...
I got my laser back glass removal machine to make a successful run the first time around on a test iPhone 8 cracked back glass and it worked fine.
But the second time around when I try to select the iPhone 8 file nothing appears. Is there any way I can recover this file somehow?
Does my TBK 958c have a software issue?
Esta é uma boa pergunta?
Pontuação 5
5 comentários:
Idem - stesso problema iPhone 7P
por
تم إعادة تعيين وتم كسر الجهاز
por
hello i need 13 p m laser software can;t dawnload
por
hi please i need new update file remove back glass iphone laser machine thanks
por
hi please i need update file remove black glass laser machine thanks
por
Adicionar um comentário
2 respostas
You save change file but you can download file from:
http://www.shenwangda.com/en/h-col-125.h...
Esta resposta foi útil?
Pontuação 0
5 comentários:
Hi Stad.
I did for a saved change file I messed up, and it worked great. BUT, the file for the iPhone XS MAX is not working from this download. The laser is missing the bottom corners of the phone.
Do you know how I can work around this issue? Or, is the file set specifically this way so the laser does NOT hit those lower corner sections on purpose?
por
Hey, I don’t know if you ever found the answer you were looking for, but I found the treasure trove of files from the company. Most likely after use something got edited with the original file and it broke it. Here’s the link to the files. You want the one with 3.0.zip in the name.
por
hi i have a problem with the laser machine is that it does not give the correct size when choosing a specific shape for a mobile device
por
the new 3,0 from the shenwangda website is .lmf3.
i have the full 2.0 with all templates before the 3.0
contact me on smurfos76@gmail.com if still needed
por
I have a tbk958f blue laser machine, but I could not retrieve the lost files. Can I retrieve the files?
por
Yes I am tray so need files
Pontuação 0
Adicionar a sua resposta
strelok será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 9,881
