Ir para o conteúdo principal
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Perguntas Visualizar todos
No numerical output on minijack
Hello,
No numerical output on minijack connector. Analog is working well. It’s surely an hardware problem. I tried several configurations in sound preferences, midi preferences. Cable is ok working on iMac.Is it possible to clean the connector ?
Regards,
Bertrand.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
To be clear you are looking trying to connect via a digital out (optical signal).
por
Adicionar um comentário
1 resposta
The digital optical signal does require a special cable like this one: Mini Toslink to Toslink Digital Optical Audio Cable 3 Ft Connector Adapter
While faint you should see a red light emitting from the cable mining it at a white pice of paper in a dimly lit room.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bertrand Clech será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 24
