Which replacement battery do I need?
Can you tell me which ifixit replacement batter I need and tool kit. Thanks
Esta é uma boa pergunta?
the battery will have the descriptor listed on the battery you are replacing. match to this when ordering your new one. for your model it is usually as16a5k, as16a8k, as16a7k…depending on the mah/ other variables. just make sure to match what is on the one you take out
Esta resposta foi útil?
Thanks - this model Acer has an internal battery so I have to take it apart to see what model it is but I will do that and order the corresponding battery.
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 856
