Suporte para carrinhos de golfe movidos a gasolina e elétricos, às vezes referidos como carros de golfe ou carrinhos de clube, após a marca de carrinho de golfe Club Car.
I have replaced coil, carburetor, fuel pump, and filters. The cat will turn over but will not start. I have squirted gas into the intake and get fire out of exhaust port but still not start. I have disconnected the ground on the rpm limiter and same thing. I have checked all the limit switches and all are working. I have fuel flow at the carburetor. I am out of ideas can anyone help with an idea. Ricky
Navegue neste tópico para encontrar o local apropriado para este comentário. Em seguida, clique em “Anexar comentário a esta postagem” para movê-lo.
3 comentários:
I can’t get my golf cart started I get fire out of the exhaust port when I use starter fluid but will not run The cart cranks but will not start. I would like some kind of an idea on what to do
@clubcar2001 sounds like it is not firing. Check your spark (not the plug but see if you get a spark. Remove the spark plug and hold it via some insulated material to some ground. See if you get a spark. Your Cart should have a Kawasaki engine (FE290 or FE360) and the error could be a bad coil or the rev limiter.
Spark Inspection
Check for sparks as follows:
• Remove the spark plug, connect it to the plug cap that is attached to the high-tension lead, and place the spark plug in contact with the engine block. When doing so, place the spark plug as far away as possible from the spark plug hole and make contact at an area that does not contain gasoline.
CAUTION
Perform the spark inspection after making sure that there is no presence of gasoline in the area in order to prevent unintended ignition.
• Turn the stop switch or the key switch ON to turn the crankshaft, and check if sparks are generated at the electrode of the spark plug.
If there are no sparks or the sparks are weak, clean the spark plug, adjust the spark plug electrode gap to between 0.7 and 0.8 mm, and check for sparks again.
If there are no sparks or the sparks are weak even after cleaning the spark plug and adjusting its electrode gap, replace the spark plug with a new one and check for sparks again.
If there are no sparks or the sparks are weak even after installing a new spark plug, inspect the ignition system.
Spark Plug Cleaning and Inspection
• Using a wire brush, remove the carbon deposits from the spark plug.
If the spark plug is contaminated with oil, wash it in a cleaning solvent.
• If the electrode is worn or the insulator is cracked, replace the spark plug.
• Using a gap gauge, measure the electrode gap of the spark plug.
If the gap is incorrect, adjust it to the correct gap by bending the horizontal electrode.
1 comentário:
I had same problem and i did the entire list of things listed, as they are correct n maybe more. total frustration .
compression check, valves, timing. everything..
then i found. the black box with all wires in it, the cable was not connected to the cam. its called electrical box cam. reconnected it. fired right up. noticed some tangs broken on it. ordered new one. the less free slack on cable the less pedal play faster cart goes.
por Ricky
Got a 350 Kawasaki got fire no combustion they put gas in the oil I done changed oil
por chris goode
Can anyone help wondering if rings are shot
por chris goode
