Ir para o conteúdo principal
O HP G71 é uma série de laptops produzida pela HP. Os laptops G71 são identificáveis pelo número de modelo G71-XXX-XX, e as terminações variam de acordo com as opções e o vendedor.
Why don't my USB ports work?
I've noticed recently that both of the USB ports on the right side of my G71 are not working correctly. Whenever I plug a device into the top one, I get a "USB device not recognized" message, and plugging something into the other gets nothing at all. The third USB port (on the left side) works perfectly fine.
Esta é uma boa pergunta?
Pontuação 2
2 comentários
Try reloading the USB drivers. Cheapest easiest fixes first then dive in to innards.
por
my cd roma worked until I update my window
por
Adicionar um comentário
2 respostas
Solução escolhida
I finally opened the computer. The ribbon cable from the USB board to the motherboard was unplugged at the motherboard. I now have all 3 USB ports functioning again!
Esta resposta foi útil?
Pontuação 4
I would remove the keyboard and check to see the connector for the USB ports on that side is firmly connected. If it is check the ports carefully for damage or debris. I am including a link the the service manual. Good luck.
h10032.www1.hp.com/ctg/Manual/c01713747.pdf
Pontuação 3
2 comentários:
Thanks for the link, I'll be sure to try that.
por
Definitely appreciate the link. Thanks for your help in this.
por
Adicionar a sua resposta
David Hodson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 3,684
