Ir para o conteúdo principal
Modelo A1297 Unibody: Início de 2009, Meados de 2009, Meados de 2010, Início de 2011 e Final de 2011
Metallic taste when using track pad
When I was swiping my fingers across the track pad i could taste a metallic substance from the computer this my second macbook pro and the first one had the same results.
Has anyone else had this problem?
Esta é uma boa pergunta?
Pontuação 5
4 comentários
This question was migrated from http://www.ifixit.com/Answers.
por Compartilhar
This question was migrated from http://meta.ifixit.com/Answers.
por Compartilhar
I think this question is a ploy to get us all licking our fingers!
por Compartilhar
I have that SAME thing! People think I'm nuts, but it happens when I use my MacBook AND my iphone. I didn't realize that it was with all Apple products for me. So weird. I have had MANY computers and phones, but Apple is the only thing I experience it with.
por Compartilhar
Adicionar um comentário
4 respostas
Solução escolhida
Have your dentist replace your silver amalgam fillings with a composite material. Your metalic taste is most likely being caused by the slight electrical current discharging in your mouth via your fillings. Read up on it here: http://www.drpgilbert.com/metallic-taste...
Esta resposta foi útil?
Pontuação 20
5 comentários:
Didn't know this was possible. +
por Compartilhar
I was thinking similar lines re small current/electrolyte problem but more localised, it's a good read.
por Compartilhar
+ Hah! I had no idea this was possible. Crazy stuff.
por Compartilhar
Did you find the answer to your problem?
por Compartilhar
Early in my life I had a dental laboratory and did crown and bridge work, went to lab school for two years.
por Compartilhar
I don't think it's normal to experience tasting flavors from simply touching an object.
That said, if you are touching an aluminum case and you lick your fingers afterwards, it's possible that you could be licking up some aluminum dust.
Either way, I wouldn't recommend licking your fingers or your laptop.
Pontuação 5
1 comentário:
My dog does that for me ;-}
por Compartilhar
I would try adding a colloidal minerals supplement in the liquid form to your diet to see if this resolves any mineral deficiencies you may have. Many of the minerals are metals. In chemistry the Theory of Equallibrium tells us that all touching matter exchanges atoms. I would also try washing your hands prior to touching the track pad. Colloidal/Ionized minerals are in the form of salts. Your sweat has salt in it.
Look to see if touching other items brings this sensation. That may help you narrow down the cause of it.
Pontuação 3
3 comentários:
that's what I was thinking.. you put it much better than i could.
por Compartilhar
I think if you had elaborated on your thoughts Poly that your words would have been more eloquent than mine. However no one seems to view our thoughts as a viable solution to the problem at hand.
por Compartilhar
ha ha..at hand! get it? ah well no one else will either. ;-P
por Compartilhar
sometimes, when i move myfingers over the metal part of my laptop, both the unibody and the one before, i feel some ‘stick-slip’. it is gone when i unplug the power. clearly, some voltage comes through.
Pontuação 1
Adicionar a sua resposta
Michael será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 39
Ao todo: 4,037
