Ir para o conteúdo principal
Guias de reparo, informações sobre desmontagem e resolução de problemas para a 4ª geração do Apple iPad com rede celular 4G LTE CDMA (Verizon), disponível com 16, 32, 64 ou 128 GB de armazenamento. Lançado em novembro de 2012. Identificado pelo número de modelo A1460.
No touch after digitizer replacement
I was brought an iPad 4 CDMA with a broken display. I ordered a replacement and when it arrived I installed it.
Everything went good with the install but there was no touch. I tried disconnecting and connecting it a few times and it did not help. I then hooked up the original broken display and everything worked so I called iFixit and they sent out a replacement.
When that one showed up I installed it and the same thing happened, no touch but the original display works.
There has to be an explanation for this, right?
What am I missing?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I don’t know what I did different, but I got the display to work.
Thank you for the replies
por
Adicionar um comentário
3 respostas
Pergunta mais útil
I went through at least 4 digitizers to get one that worked properly on an iPad 5. The bad units partially worked — they had dead spots on the touchscreen. Never saw one be completely dead, but I suggest trying again. Make sure you’re getting the correct generation/model digitizer.
Esta resposta foi útil?
Pontuação 1
I tried pretty much the whole display on both of them and nothing.
The home button that came with both of them does work.
I’ve double checked the model number, so I don’t think that I ordered the wrong part.
Pontuação 0
Another possibility is that the flex connector is getting dislodged during re-assembly. When you pull up the digitizer check for damage to the flex cable. If it’s ok, then re-seat the cable and test with the unit open to see if you get any response.
I haven’t done gen 4, but on gen 5 the flex cable had to be folded just right for it to fit in without damaging it.
Pontuação 0
Adicionar a sua resposta
sunruh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 402
