Red Ring of Death
I have a RRoD. When I turn on the Xbox the power supply goes yellow, green, red, then yellow. I have no hard drive so I have no error code. Please help me fix this.
Esta é uma boa pergunta?
Sean 29 this sounds like something went wrong with your power supply. Possibly something that shorted out with the “sprayed air in the power supply “ Time to open up the power supply and take a look at it. Remember so that there are a few of them out there and we would need to know more about the power supply. Check on here about a description on how to tear it down. Xbox 360 Power Supply Teardown Once you have it apart you can post some good pictures with your question showing the innards of the poweradapter so that we cna se what you see. Adicionar imagens a uma pergunta já existente
Guia
Nível de dificuldade:
Moderada
15 - 30 minutes
Guia
Muito fácil
2 - 5 minutes
Esta resposta foi útil?
Do you know how to get out screws that are screwed in too much?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 140
2 comentários
Sean29 has it worked for you before? What happened to your Hard drive?
por oldturkey03
Yes it work before, it didn't come with a hard drive. The old owner showed me it worked. The problems started after I accidentally sprayed air in the power supply.
por sjamesmm
