Ir para o conteúdo principal
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
20 Perguntas Visualizar todos
Why wont my phone charge?
I dropped my phone and it will not charge after the drop. When plugged in, it turns on and off on a cycle and the battery logo comes on. It will show the logo for a few seconds and then continue on a loop.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Cesar Ramos  the looping can be an issue with the battery/power. Check to make sure that the battery is still fully seated and that it makes proper contact and that the battery flex is not tore. You will have to do a bit of disassembly for that. In your phone case and if this still the original battery, I would replace it at the same time. HTC One M8 Battery Replacement
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Cesar Ramos será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 54
