Ir para o conteúdo principal
Fones de ouvido esportivos sem fio, sucessores do Backbeat Fit.
Headphones not charging - possible error code?
When connected to power, the device flashes red light 15 times and then doesn’t charge. If i depress the power button once during the flash sequence, the red light goes steady and the device charges normally.
Is the 15 flashes an error code? It’s not mentioned anywhere by Plantronics.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Does it always consistently flash 15 times? If not, sounds to me like you have a borked USB cable.
I've also had an issue in the past where the light went solid red and didn't charge. I figured out that the cable between the ears was damaged and had to order a new headset
Esta resposta foi útil?
Pontuação 0
1 comentário:
how did you figure that out?
por
Adicionar a sua resposta
Henry Collingridge será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 583
