Ir para o conteúdo principal
Guias de reparo e do dispositivo para o smartphone Xiaomi Redmi Note 7 Pro.
touchscreen not working after software update
i had broken my touchscreen so recently i got it replaced by a first copy(unoriginal) touchscreen. it was working fine till i updated my software to MI10. After that it stopped responding entirely. what should i do? will downgrading or a factory reset solve it?i still haven’t tried either of the two options.
Esta é uma boa pergunta?
Pontuação 3
1 comentário
Dear Sir
Mi 7Pro Scaren not shoing
por
Adicionar um comentário
6 respostas
Pergunta mais útil
i am using redmi note 7 pro , just now i have updated july 2020 patch and it stopped my touch . Now my phone’s touch is disabled. However i went to MI service centre and shown them this , it was software issue they hard reset my phone now it is working. this suckss .I lost trust over MI next time No MI phones .
Esta resposta foi útil?
Pontuação 2
2 comentários:
Same problem issue is solved but same problem happening again and again it stop touching need to wait 2 to 3 hours and it works again...
por
No use of it…
You can try some tricks but wont say it will definitely work for you
por
I don’t have any experience of this issue on this device however whenever I encounter this sort of problem I would attempt a reset first then another software update. If that doesn’t work I would attempt to downgrade, if that doesn’t work there’s possibly a physical issue with the new screen. I would expect the reset to solve the issue.
Pontuação 0
Same problem here a year after un Redmi Note 8nPro. Xiaomi is disgustting, I'm angry. Touchscreen stopeed working after MIUI 12.5, how the !&&* don't they solve this??
They just killed my phone.
Pontuação 0
Redmi Note 8 Pro, screen oem replaced, worked fine until the last update, now it has no touch.
I was a Xiaomi supporter and i recommended their phones to all my customers,
I will still recommend them, but only to my enemies.
Pontuação 0
First try to downgrade the software..
Pontuação 0
Screen touch problem
Pontuação 0
Adicionar a sua resposta
Shreyasee.zelomak Stan B.a.p será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 34
Ao todo: 6,063
