Ir para o conteúdo principal
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Perguntas Visualizar todos
Spilt water on MacBook, but cannot remove battery
I spilt some water which has gone inside the computer. I stupidly tried swithching it on before allowing to dry. It came on shortly and then went off. I have removed the back cover and want to remove the battery as recommended in other solutions. I cannot do this however as I do not have a tri-wing screwdriver.
1 Is it really essential for me to remove the battery?
2 Is there a way to remove the battery without a tri-wing screwdriver?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I have managed to remove the battery. Should I leave the bottom cover off while the computer dries?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
A screwdriver from Radio Shack is a lot cheaper than a logic board replacement.
Esta resposta foi útil?
Pontuação 2
5 comentários:
Unfortunately I live in Zimbabwe and its 9p.m at the moment.
por
Ouch! Now is the time to improvise a tri-wing somehow. You do need to remove the battery. Good luck.
por
What, no Radio Shack in Zimbabwe, what's the world coming to? ;-)
por
Got the battery out with a flat head screwdriver
por
Here's the guide on water damage: Electronics Water Damage
por
Adicionar a sua resposta
Wilson Luke será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 2,947
