using panel as external display of iMac 2009
So I want to use my 2009 mac as an external display. i found the panel to be LM240WU2-SLB2. and i bought this board https://www.aliexpress.com/item/32973681....
When i connect the panel to the board I get a green light suggesting it is getting signal but the display is black. I am thinking that is because the board kit doesnt include inverter.
Thing is I am not sure if this requires an inverter as according to panellook.com it says it is with inverter. http://www.panelook.com/LM240WU2-SLB2_LG...
So my question is: Do I need an inverter for this panel? And if I need an inverter I am not sure which inverter to get. pls suggest. thanks.
Update (02/14/2020)
I've looked at this post but none of the links posted in the answer work
Can I Mod an early 2009 24" iMac to external monitor?
And some other sellers of the board have this weird contraption which they are not selling along with the board and I am not sure what it is. https://www.aliexpress.com/item/40002754...
Esta é uma boa pergunta?
