Ir para o conteúdo principal
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318 Perguntas Visualizar todos
Mister in rear of Dryer stays on, items come out wet.
Cycle completed as normal, but mister was spraying clothes and created a puddle at filter. To cut it off, I clode eater values to washer & dryer and unplugged dryer. Any suggestions. Tech Sheet has not provided needed insight.
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Please give us your model number. Also what is "clode eater values"
por
Thanks for the quick response. Sorry for typos on my cell. The correction should be: "closed the water valves". Further discussion with my wife and I learned that she had used the Refresh Cycle and after it completed the clothes were wet - the Mister continued to spray, etc. The Model # is 110.86762701 Ser# MW1601196 Purchased in 2008. Type:DADT-ELE-2406024-EL54. Electric Dryer, not Gas.
por
Adicionar um comentário
1 resposta
Hi @ijamsville ,
Don’t know the answer but in the SteamCare cycles i.e. Refresh and Touch Up a water inlet solenoid (see part #59 bulkhead parts) is operated to dispense the water.
Does the Wet light come on in the Steam cycle? According to the owner manual this indicates that water is being dispensed onto the load and presumably it goes out when the water is shut off. Don’t know if this is correct though.
If it doesn’t stay on maybe it’s a sticking solenoid valve.
If it stays on then perhaps there is a problem with the dryer user interface (part #18 Top and Console parts - supplier example only) maintaining the solenoid operated when it shouldn’t.
If it is determined that it is the control board just search online for W10110646 to find suppliers that suit you best
Does the tech sheet have a test for the Steamcare cycles at all?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Douglas D Bradham será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 680
