Ir para o conteúdo principal
Announced on October 16, 2014, identifiable by the model number A1347 and EMC 2840.
197 Perguntas Visualizar todos
My Mac Mini has no slot for an SSD. What are my options?
I have a Late 2014 non-fusion drive Mac Mini that I had planned on converting to a fusion drive by installing a 128 GB SSD into what I assumed would be an empty slot and pair it with the stock mechanical drive. Unfortunately, when I removed the cover I found that there is not slot on mine. I’m assuming the non-fusion drive models did not come with that port populated? Is there an economical way for me to add a flash drive to this model or is my only option to pretty much just replace the stock mechanical drive with a 2.5” SSD?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Adding SSD Drive to PCIe model appears to have the answer. I also found this fairly detailed explanation of exactly what I was trying to accomplish https://ghouletech.co.uk/upgrading-non-s...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Larry Jorgenson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 39
