Why will the door behind the driver not unlock with key
All the other door locks unlock with the key with the exception of the one behind the driver.
Esta é uma boa pergunta?
Hi,
Do you mean that the rear door power lock actuator doesn’t operate when you press the key or that you cannot open the door from the inside when the door is unlocked?
If you cannot open the door from the inside then check if the rear door security lock is activated.
Here’s an image taken from the owner manual that may help.
(click on image to enlarge for better viewing)
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 102
