Ir para o conteúdo principal
Announced on October 16, 2014, identifiable by the model number A1347 and EMC 2840.
197 Perguntas Visualizar todos
PPM002 Error in Diagnostics but memory tests pass
Hello
I have a Mac mini Late 2014, it works fine when im using it but cannot update OS not install new one, each time I try to do it, it comes with up error and points to running diagnostics due to a hardware fault. Ran diagnostics and came back with PPM002 error pointing to an issue with memory module (crappy onboard on this version of Mac mini so can't replace). However when I Run a memory test software like Rember (I've tried a couple of others too) all memory tests come back with no issues. I've attached pics of the diagnostics screen as well as the memory tests.
Any help is appreciated.
Esta é uma boa pergunta?
Pontuação 2
3 comentários
Did you try a fresh set of SO-DIMM’s?
What is the amount of RAM you have mounted?
Sadly RAM testers are not perfect! I would trust Apples as it tests the lower range better than OS run testers which can't reach the lower address lines.
por
The RAM is soldered on this Mac unfortunately otherwise would have tried before posting the question.
por
Your right I was thinking the older 2012 model! My mistake. Need that second cup of coffee this morning ;-}
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Sadly your logic board has a problem with one of the RAM modules.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Faisal Gondal será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 50
Duração total: 7,163
