Ir para o conteúdo principal
Repair guides and troubleshooting for the Acer Aspire 5750. This is a 2012 Aspire budget laptop aimed at the casual household user or for small business use.
26 Perguntas Visualizar todos
power jack problems, any ideas?
the power jack on my acer aspire 5750 seems to be loose. and when i tug on the power cable, the computer just stops charging at all. is this a common problem? and if so, is there a way to fix it?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Ethan Rhoads not sure about common but it does happen. You can repair the jack yourself. Use this document acer_aspire_5750_5750g_sm.pdf page 3-30 to get to the jack etc. It is soldered onto the board and will require some soldering. Check this video for more info.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
Ethan Rhoads será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 112
