Ir para o conteúdo principal
A sétima iteração do iPod Touch da Apple, lançada em maio de 2019. Este modelo vem com até 256 GB de armazenamento e um processador A10. Número do modelo A2178.
How to fix a dropped iPod?
I dropped my Ipod on the ground about an hour ago and it is just the glitchy screen with the lines. How do I fix this techy people? <SOS>
Update: I let it die and then plugged it in and left it alone for a couple hours and it seems to be working fine now. There is still some slight screen flashing but it’s almost unnoticeable.
Esta é uma boa pergunta?
Pontuação 2
7 comentários
Is the screen flickering still happening?
por
slightly, yes
por
Its possible you loosened the connection on your motherboard. There's no cracks or anything on the screen?
por
Awesome glad to hear! It was totally the big UwU energy that fixed it.
por
okay you have to be one of my favorite people in the entire world
por
Exibir mais 2 comentários
Adicionar um comentário
4 respostas
Solução escolhida
it seemed to have fixed itself, thanks for trying though, it means a lot to me. :>
Esta resposta foi útil?
Pontuação 0
thank you i would cry if it is broke
Pontuação 0
1 comentário:
Thank you SO MUCH for this solution. My iPod was flickering after I dropped it, no matter what I tried. But I turned it off (powered off) and let it rest a few hours and the flickering was fixed. I’m so grateful 🙏🏻 . (Note: one hour was not long enough, was still flickering)
por
My iPod drop and it won’t come on
Pontuação 0
1 comentário:
If you scroll up you’ll see that others have said they let it die and then plugged it in and left it alone for a couple of hours and then turn it on again, this fixed the problem. Their suggestions worked for me. Good luck.
por
it happens with all 7th gens i wanna believe, when you drop it it kinda like makes the phone panic and renderitself useless like some sad lil puppy on the side of the road. just hold the power,volume, and home button down which resets it and when it powers back on it may flicker but thats only because the LCDs were a bit burned for a bit but will ultimately go back to its normal state within a few hours. it depends on how long the phone was in that state. the longer the phone has the lines the longer the flickering and the lines will appear on the screen. I dont know what causes this but if anyone knows please tell me. im very curious
Pontuação 0
Adicionar a sua resposta
UwU_Person será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 9
Últimos 30 dias: 36
Ao todo: 6,073
