Ir para o conteúdo principal
The DJI Phantom 3 Advanced is a remote controlled flight system released in April of 2015. Model Number:WS22
Wont connect to app. Status light controller flashing green?
Hi everyone
Could someone please help me ? I have spent hours and days on the internet trying to solve my problem with my dji phantom 3 advanced.
1. Green status light on controller flashing instead of solid ?
Cannot find anything about this or anyone having the same problem.
2. DJI Go app on Galaxy S8 wont recognise or connect to my phantom 3 advanced ?
Read numerous posts about this problem and none of the recommendations work. Tried numerous different cables to connect also tried my wifes Galaxy S7 and daughter's iPhone 8 but still no joy.
Controller connects to drone ok and I can fly in line of sight but seems to be stuck in beginner mode. Restricted distance.
Everything worked fine when I last used it about 6 months ago. I can update firmware on drone but without being able to get dji go app working I cannot update my controller .
In the DJI Go app it wont let me get past "How To Connect"
Please can anyone HELP
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
# If green blinks slowly on the controller, the standard-status is : “Inactivity for over 6 minutes. Switch off the remote controller if it is not in use”.
  1. In some cases, the USB-connection will stick in “load-modus” . In my case I resolve it by using a universal USB-driver for Android. In this app. you can switch to another modus than load-modus ( i.i. data-modus MTP OR PTP, USB ETHERNETmodus) you can set these options only in USB-debugging ON. In my case I have success with this app.
  2. Suc6
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Daniel Moore será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Ao todo: 1,189
