Ir para o conteúdo principal
This laptop is manufactured by Asus, has a 15.6” touch screen display, and runs Windows 8. Model number: ASUS Q550LF-BBI7T07.
How to replace the screen on my Asus Q550LF?
The screen on my Asus Q550LF got damaged and no longer works, I need to replace it and was hoping to get some instructions on how to do the installation properly.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
https://www.youtube.com/watch?v=wgM6jfmr...
That's a video for replacing the screen on a Q550lf. Not sure if it is quite the same build, but at a glance they appear to be similar. Should at least provide you with a starting point since there usually isn't too much of a difference in how things are connected.
For other BBI7T07 section replacement references, please check out below guides.
ASUS Q550LF-BBI7T07
Or for quick troubleshooting:
ASUS Q550LF-BBI7T07 Troubleshooting
Hope my answer comes in handy for you.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Subash K Cox será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 444
