Ir para o conteúdo principal
A Vornado circulator uses special airflow called Vortex Action to circulate all the air in the room. The air flows fast, cool and constant to create a cooling experience unlike any other.
It powers up for a split second then stops.
Looking on pointers on how to fix this problem. The fan powers up for a split second, then turns off. Pressing the 4 speed buttons on the control panel gives no audible response. Only the power button responds. Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
How old is the fan?
According to the user guide there is a 5 year manufacturer’s warranty on the fan.
If the fan is not that old, contact the manufacturer as per the warranty statement in the user guide.
If it is older than 5 years, then the fan speed controls would be the first place to check as it may be a problem in the speed button assembly or what they connect to.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
yungminglee será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 43
Ao todo: 1,370
