Rear headrest deployed. How do I get them down
2001 CLK Convertible my rear headrest deployed. How do I get them down
Esta é uma boa pergunta?
richard morris check this video and see if it works for your model as well. Or you can try what works for the 2000 CLK . You can reset them with the button that you normally use to adjust your headrest. To reset the rear headrest, which MB calls a roll bar, press the upper half of the button and hold it for 8 seconds until you hear the mechanism engage, then press the lower half of the button to lower the headrests.
Esta resposta foi útil?
Thanks oldturkey03 your Vedio is for a 2005. My car is a 2001. I tried pushing the button to the left of flasher and it did nothing
@richard morris I added the instructions from the 2001 CLK owners manual.
Hello. I have 2004 clk 500 that I cannot figure out how to lower the rear head rest. this car does not have the roll bar button thanks.
Últimas 24 horas: 2
Últimos 7 dias: 38
Últimos 30 dias: 240
Duração total: 9,646
4 comentários
How do you get them back up I heard the noise on the button but nothing move thanks
por keithjones147
I have a 2007 s550 and the same thing happens with my car……. I hear a click but head rest stays up🤷🏾♂️
por oscar.summerlin
Mercedes benz ml350 no change ger at hot car
por Fazl
How can I manually lower the rear headrests in my 2004 Mercedes FLK 500?
por Mark Carter
