Ir para o conteúdo principal
The production third generation Quest was unveiled for the 2004 model year at the 2003 North American International Auto Show.
9 Perguntas Visualizar todos
Nissan quest only goes 5mph
How to change the vvt control solenoid valve on a 2004 Nissan quest
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
Here’s a link to the Engine Mechanical section from the repair manual from the 2004 Nissan Quest repair manual.
Scroll to p.EM-47 to view the procedure to remove the front timing chain case.
At Step.28 on p.EM-50 the IVT control solenoid valves are removed.
Here is a link to all the various sections of the 2004 Nissan Quest repair manual some of which you may need to do the repair e.g at Step.2 in the procedure it refers to MA-14 draining engine coolant. This is to be found in the Maintenance section of the manual on page 14.
Here’s an image taken from p.EC-425 (Engine Control ) that shows how to test the solenoid which may be of some help.
(click on image to enlarge for better viewing)
It may be easier to use the manuals by downloading them to your computer. To do this when the relevant section has opened in the Document box, click on the Download icon (next to the Zoom 100% notice) either at the top or bottom of the page.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
kimberly hayes será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 113
