Ir para o conteúdo principal
The De'Longhi EC155 is a Pump Espresso and Cappuccino maker.
Cleaning the boiler outlet
I can’t get the screw out to clean the boiler outlet. It seems to be welded in. Water won’t pump through. Do I have to throw the whole machine away because the screw won’t come out?
Update (01/08/2020)
Here are the pictures of the screw I can’t get out and the boiler holder (holds the coffee filter).
Esta é uma boa pergunta?
Pontuação 2
2 comentários
jwsacco post some good pictures of what you are up against. That way we can see what you see and hopefully help you out.Adicionar imagens a uma pergunta já existente
por
I can't get the screw out. It's stuck fast. I have tried WD40. Any advice would be appreciated.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
jwsacco it is not welded in. I think it is just hard to get a good grip on it. Use a phillips head socket and a ratchet. Place the socket into the screwhead and use a small hammer to tap the bottom of the socket thus loosening the screw a bit. The use the ratchet on the socket to remove the screw.
Check the first 45 sec off this video
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
jwsacco será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 38
Ao todo: 3,053
