Ir para o conteúdo principal
Lançado em junho de 2016, o Altec Lansing BoomJacket 2 é um alto-falante Bluetooth pequeno e portátil. Ele foi projetado para funcionar em qualquer lugar sem a preocupação de ser danificado pelos elementos. Número do modelo IMW579-AB-BB (azul água)
My speaker stopped charging.
I've had an apparent short in my circuit forever but always found a way to charge it, by positioning the speaker just right. Now it is not charging at all. Any suggestions?
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
I am having the same problem, but I have isolated it to the power input board. Part number 30-678 Jack MP1.
por Compartilhar
My micro charge connection is damaged. Can anyone recommend a repair center? I reached out to altec lansing but they want proof of purchase. I don’t have my receipt. Any assistance will be great full. TYIA..
por Compartilhar
My micro input is fine. The center conductor looks like it’s pushed in.
por Compartilhar
Adicionar um comentário
1 resposta
My best suggestion would be to replace the charging cable if the problem is cable side. If it's the plug itself unfortunately your going to have to open it up and do some soldering.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I am having the same problem, but I have isolated it to the power input board. Part number 30-678 Jack MP1. The USB connector has come apart and the board needs to be replaced. You will have to find an Altec Lansing repair shop to order a replacement board. Since the speakers are water proof you will have to pry the connecter out of the shell in order to remove power board and it will get ugly.
por Compartilhar
Adicionar a sua resposta
dpadget3 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 33
Ao todo: 774
