Ir para o conteúdo principal
Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
Apple Watch Wont Turn On After Trying to Fix Adhesive
Okay so I was stupid for doing this and it was my first time messing with apple watches internally. I was following ifixits guide but was scanning through and didnt see that the cellular watches battery connector is in a different spot so i unplugged the screen while the battery connector was still plugged in(the watch was turned off) and then i may have slighty scratched the surface of the screen connectors when trying to pull them out but I dont know if this actually affects them or not(its just a small scratch on the cable), but know the screen wont turn on at all and I just feel it vibrating and stuff, what do you think happened to it? Thank you in advance!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The most likely issue, if all of the ribbon cables have been properly seated back into their connectors, is that a ribbon cable was damaged.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
lanerfloyd107 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 77
