Ir para o conteúdo principal
Scratch on LED television screen
I have a 1/2” scratch on my TCL 40” LED television. It shows white when tv is on. Is there a fix for this? I have tried the Vaseline and the art eraser “fix” with no luck.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
tkbaldwin  what you describe “It shows white when tv is on “ sounds actually more like a bad LCD. Either way, there is no fix for it. You would have to replace the screen to eliminate it. If it is not to bad I would try to learn to live with it for a bit longer since screen are very hard to find. You can always post an image of what your screen shows so that we can verify what the damage is. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
tkbaldwin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Ao todo: 1,679
