Park lights won’t turn off
Park lights stay on after vehicle is turned off
Esta é uma boa pergunta?
@harv177 common issue on the H3 is a short in the trailer wiring touching the chassis and causing issues. Open the tailgate and carefully inspect the wiring harness. Pull the Trailer B+ fuse and see if that turns the lights off. If it does you know it is a short in that wiring. If it does not, check the light switch with a multimeter.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 706
