Ir para o conteúdo principal
Pergunta encerrada
Can I use it as a display?
The computers logic board is finished, how can I rig it to work only as a display?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
5 respostas
Solução escolhida
In short you can't, no easily. You'd need to disassemble and figure out a way to connect the cable that normally goes to the logic board to some sort of adapter. My french is horrible but apparently this thread http://forum.macbidouille.com/index.php?... is all about figuring that out. good luck.
Esta resposta foi útil?
Pontuação 0
Typically you can't.
Pontuação 0
No, It can be used only as output for the motherboard. You may want to think about getting another Motherboard.
Tim
Pontuação 0
You might be better off selling the unit for parts, and taking the money to buy a new 20" monitor :(
You'll probably end up with some leftover cash in the process!
Pontuação 0
I agree with David, its much simpler and you'd be better off selling it for parts (if iFixit for example!) and then putting that money into a real, newer display.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,600
