Ir para o conteúdo principal
Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
387 Perguntas Visualizar todos
Ripped off power supply from motherboard. Is this fixable?
So I ripped the power supply adapter off the motherboard and I couldn’t find any other person with this type of problem. There are no soldering points, and I need to know if this is fixable or if the motherboard is just trashed. Thanks for the help!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Yes this can be repaired, but not easily unless you have experience. The pads must be repaired before the connector is reattached. Also, there will need to be additional support for the connector otherwise it will easily be torn off again. This is not a repair that should be attempted without prior experience. Contact a local repair show and bring along the connector and the board (in a static bag).
Dan
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Richard Chatt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 436
