Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Perguntas Visualizar todos
monitor won't stay illuminated unless I open it very wide or narrow
When I am using my MacBook white 2008 with battery or ac (not a power issue), the monitor needs to be in one or 2 very specific positions in order to make it light up. I think it might be a switch in the hinge or something. Any advice?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
sounds to me like it's your inverter cable. see this guide for replacing it.
MacBook Core 2 Duo Inverter Cable Replacement
as for teh cable itself, please provide us with the last 3 digits of your serial number and we will be able to provide you with the exact part number as there are a few versions of the cable.
Esta resposta foi útil?
Pontuação 1
I agree with pierrej, if you can still dimly see the desktop when it goes out. Here's my guide on that: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
If you can't see the desktop, you will most likely need to replace the Display Data Cable. We need that serial number.
Pontuação 0
Adicionar a sua resposta
Erik será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 357
