Ir para o conteúdo principal
Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
Apple watch 3 : No touch after screen remplacement
Hello,
I’ve replaced my apple watch 3 GPS screen assembly, and got no touch.
I’ve tried force restart, cleaning the connector with Iso Alcool.
But I’ve notice a sticker broken on the bottom half of the ribbon cable.
Or do you know hos to diagnostic a broken cable ?
Thx!!
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Have you contacted apple support
por
No because i replace it myself, so Apple won’t help me.
por
Did you ever find a solution? I have the exact same problem.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
If you have a torn ribbon cable it is game over. The black tape broken is not a problem. I have documented my own problem with no touch after replacement and had to reseat the ribbon cable in the display screen connector for touch to work.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks for your answer!
The ribbon cable is slightly bend but not torn, so i suppose it's not that.
And i tried to replug it using your guide, no change.
It their a special way to plug the middle ribbon ?
por
Have you removed the battery before replacing the LCD. If not, remove the battery first and with display connected and press the power to remove any static charge in the components. It could give a chance. Careful while removing.. Don’t use too sharp objects as spudger and double check the battery connector while replacing.
Pontuação 0
1 comentário:
I just tried it and it doesn't work either.
I don't understand, nothing look damage or missing....
por
Adicionar a sua resposta
freyjamir será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 787
