Ir para o conteúdo principal
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Perguntas Visualizar todos
Pergunta encerrada
Frozen display
I have an i mac (intel) model i mac 7.1; 2.4 GHZ IntelCore 2 Duo processor with a Mac OS X. My display is frozen. I've shut it down and unplugged it several times. I've used several ways to shut it down. When I restart the computer it gears up and then the display is frozen. My mouse works and so does the network. Any ideas about what else I might try? Would greatly appreciate any help. Thanks, Paula
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Apple iMac "Core 2 Duo" 2.4 20-Inch (Al) Specs
Identifiers: Mid-2007 - MA877LL - iMac7,1 - A1224 - 2133
por
At what point is it freezing up? Does it boot all the way up? With your mouse and network working, I would guess it locks when opening a program.
por
Adicionar um comentário
2 respostas
Hi,
You say your mouse works... How do you know, or rather: what do you mean by this?
I sort of have the same issue: sometimes the screen freezes, EXCEPT for the mouse-cursor.
No response whatsoever of anything (no names showing up under the icons of the dock when you hover them, no window accepts clicks etc.) but the cursor still moves!!!
I can log in via the network, the machine seems to run ok...
I'm hesitating to replace the video board, $250 !!!
Paul
Esta resposta foi útil?
Pontuação 0
I have the same issue but installed also a snow leopard version because I have also troubles with Flash setting screen not working. It doesn't do it on snow leopard so I have the feeling it's a lion issue and since the imac is an old one they're not rushing themselves to sort it out.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 781
